99 GSR leathers on a DB2
do they fit front and back seats ? or is there gaps or something ?
I don’t think so, try the search bar.
gsr leather isnt a direct bolt on.i remeber seeing only 3 of the 4 bolt down.and i know for sure there is a gap on gsr leather for the rear.
no the fronts defintely dont fit perfectly and neither do the backs… theres two ways you can def put the fronts in, im not sure about the rears fitting in a four door… but for hte fronts either switch the bottom rails with the ones off your DA which looks like a major pain in the ass… or just use the rails off the gsr seats, buy some sheetmetal screws and drill four holes and mount the front seats that way… perfectly fine if your willing to make some holes, they dont move and are just as safe as the stock seats… as for the power seat belts, your going to have to take off whatevers in the way on the GSR seats for these parts to fit comfortably then once they do take the bolt to a bolts store and get a longer one (the big bolt that mounts the power seat belts to the seat) then put the seatbelts onto the seat and mount… since your wanting to go leather, just get the rears redone in leather or find some rear leathers from a db1… hope this helps, if you need more help i can show you how i did it on my DA coupe…
I have them in my DA 1 bolt hole doesn’t line up but I drive it to meets only. This year during the teardown I’m going to fix that issue
