a/c and heat
My a/c doesn’t work anymore , I’m thinking it’s because the system has to be recharged , which is cool .But my heat just stopped working, it won’t even come on, the fan doesn’t turn, I turn the knob and nothing happens , any input would be deeply appreciated , thanx!:confused:
Check the knob itself, it is probably cracked on the back and isn’t actually turning the switch. If that is fine, then your blower motor probably went out. Had to replace one in a CRX last week. Pain in the butt.
i just had this same problem with my legend, the a/c is a tricky system. if the blower motor doesn’t turn on it is probably the motor. Hopefully it isn’t the head control unit which it sounds like which is the most expensive to fix.
Check the blower resistor before replacing the blower motor. It’s much cheaper and easier to replace. Do a search for blower resistor and you’ll find out how.
