A/C help needed guys
Well guys, I finally got the a/c running in my car due to a lack of freon, but now i have another problem that has arisen. Well what i have noticed at night is when i turn on the a/c and the compressor comes on, my headlights dim a little bit and when I turn them off then they go back to the way they are supposed to be. Any ideas guys on what could be causing this to happen? Also the car seems to start have a little vibration when the compressor kicks in as well, im not sure what is causing that too. If you guys have any idea what could be the problem for these two symptons, let me know, TIA guys.
those are the same thing.
ur idle is dropping to low
Dont worry about it. All the g2’s do that, as do all honda’s as far as I know.
The compressor puts such a large draw on the charging system that those things happen.
If you really bugs you then you will have to look into a higher amperage alternator.
Later,
BR
