A few electrical problems!!!
First of all my abs system isn’t working, I get the code 4-8 but I don’t even get any resistance or voltage,
Second of all, my cruise control doesn’t work. The button on the dash is workin fine but when I press set, nothing goes on.
And the last problem is that my rpm in my cluster is pretty sick. I goes to my rpm thatthe motor is running and suddenly it starts going down and up and down. Sometimes it stops on the good rpm, sometimes it goes to zero and stays there and sometimes it never gets to the good rpm nor does it go to zero but goes wak all the time!!!
please help me.
For the cruise control, if you have a manual you might wanna check the clutch pedal. There should be like a rubber stopped. If that’s missing then that could be your problem.
