[QUOTE=rollinmyda;2330943]Those two hp/tq ratings sound like the variance listed between the P8R spec and P75 spec models of similar generation. Are you sure the stepwagon came with the P8R? Maybe they used both types of head and the rating you found was with a P75 head?
You really want to use an ecu mapped for the B20. The LS ECU will run the engine fine in closed loop but in open loop it will run it lean. I was seeing AFRs in the 16-17:1 in open loop while using a P75 on my B20. It just doesn’t deliver enough fuel for the B20 until it’s compensating using the 02 sensor.[/QUOTE]
the numbers i listed were cited from b20vtec.com in their faq section, which they acquired directly from the japan honda website.
here is web address of the faq im referencing.
http://www.b20vtec.com/forums/threads/31171-B20-non-vtec-FAQ-Guide
i found a statement on a different forum. saying the first digit of the serial number on a jdm b20b is either a 3 or a 5.
the 3 = low cr
the 5 = high cr.
the jdm b20b in my da waz originally imported HmMotors which they confirmed mine to be the 9.2 cr b20b.
“You really want to use an ecu mapped for the B20”
- agree, i want to source a 98 jdm orthia ecu, and the oem distributor, for it and do a obd0-obd2_ conversion.
instead of using a p75 or p28 be it stock or it having modified fuel/air maps and ignition timing tables originally designed to run a smaller displacement, lower compression, as well as it being a lower rated engine. in power output.
. The LS ECU -
(the pr4, or the p74, p75, ecus,?)
in “closed loop”
closed loop is when the ecu isnt actively reading real time sensor data and making real time adjustments to afrs right?
but in
“open loop”
open loop is when the ecu is actively reading the o2 to adjust the afrs, right?
andit will run it lean. I was seeing AFRs in the 16-17:1 in open loop while using a P75 on my B20. It just doesn’t deliver enough fuel for the B20 until it’s compensating using the 02 sensor.
so is the fuel delivery issue a fuel hardware issue, or is it a tune issue?
reason i opt for a p75 is that id like to run a knock sensor and the p28 wont recognize it, regardless of tune
right now im runnibg that b20b
off a stock obd0-pr4,
one rear mounted and malfunctioning single wire o2 sensor,with a frayed sensor wire,
the dash cel light always turns on so i just flip the key backwRd in the ignition and flash the ecu, the red light blinks code for o2, why i say its malfunctioning thst is.
and the
the stock obd0 1.8l distributor,
with ngk r heat range 7 spark plugs, and
93 octane pump gas, lol
