what is the firing order for the b18a1? how many quarts of transmission fluid does the transmission take? Its a 5 speed.Thanks in advance!
firing order is 1,3,4,2
distrubitor
3 4
1 2
engine
4 3 2 1
front of car
2.3quarts is the capacity of th transmission IIRC, use 10w30, Honda MTF, or GM syncromesh
Thread closed due to vague thread title.
http://www.g2ic.com/forums/announcement.php?f=35&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
