A little help guys?
I am looking for two threads and yes I did search…
1st one is the JDM sidemarker thread where it shows all measurements and then has pictures too. All that I could find is one where they mentioned that it should be, 8cm is measured from the edge of the fender panel, the 10.4cm is measured from the edge of the black bump strip. A little more information would be nice to have.
2nd is the thread about how and where to cut the DC side skirts.
Sorry if these are some place im not looking but I have been looking on and off for like a week now…
http://www.g2ic.com/forums/announcement.php?f=31&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
