I picked up a ls motor and trans but the trans is not a ys1 it is a a1 I can’t figure out exactly what car has the a1 trans can anyone help? I found things saying its from the 90 91 integra ls and then other stuff saying that’s not true. Thank you
is it cable or hydro?
Cable
I believe that the A1 came in any 91 Integra that came with a LS Motor and it is basically the same as a long geared S1 that came in the 90 Integra’s with an LS motor it also shares the same clutch as the long geared S1 transmission
So if I try to order a new clutch I should or it for a 91 integra ls ?
90-91 LS Integra used the same clutch disc. so you just need a clutch for either a 90 or 91 integra LS either one will work.
