are all B-Series Oil Pans the same???
Will a B16a Oil Pan fit a B18a or a B20b ??
Yes a B16A pan will bolt up to a B18A or B20 but the sump design is a little different… . and the effects I’m unsure of.
anyone know if the b16a pan will work ok with my b18a?? looks like it will bolt up but will i have any problems with a stock b18a bottom ???
Anyone know if the Moroso pan has any clearance issues on a G2 w/ B18A1? N/A or Turbo?
Re: ? about Oil Pans
No, they’re not all the same. I know for a fact that the '94+ Integra oil pan is not the same as the 90-93, or at least the part numbers are different (found that out the hard way:roll: ). And I also know for sure that the '94+ GSR oil pan does not work on the LS motor.
if you use the b18c girdle, pickup & baffle then the b18c pan will work on an ls ![]()
is anyone selling the b18c girdle, baffle and oil pan?? Possible witha tap for an oil temp sensor or Turbo return line??
