Hi,i saw at TEG TIPS have a topic about vtec indicator light DIY,
But without picture overthere,
Hope some one can help me…
I have a 12V indicator light,
Should i just direct wiring the light to ECu or need to use a relay for better?
If using relay,
Picture as below it’s OK?
Really thanks a lot about your reply…
May i ask you a favor,
Can you tell me the easy way please?
I think is my language problem because nomatter how many time i read your post,
I really cant understand it…
Please pardon me about that…
The only thing you need to change, [from diagram posted] is the power for the relays #30 terminal, you now have it comming from the ECU, [split for #30 and #86] leave #86 from ECU, [relay control] but get power for #30 from someplace else, it can be any power that is hot when ign. switch is in the run position, [engine running].
That way the ECU is only supplying power for the relays coil, [less then 250mA] and power for the bulb comes from another source. 94
[QUOTE=fcm;2039653]The only thing you need to change, [from diagram posted] is the power for the relays #30 terminal, you now have it comming from the ECU, [split for #30 and #86] leave #86 from ECU, [relay control] but get power for #30 from someplace else, it can be any power that is hot when ign. switch is in the run position, [engine running].
That way the ECU is only supplying power for the relays coil, [less then 250mA] and power for the bulb comes from another source. 94[/QUOTE]
Install a 3A fuse on the lead from the ign., [#30] use 2nd ign. free pin on the under dash fuse box.
No fuse is needed on the ECU lead to the relay but a 1A diode should be installed before the relay, [#86], this will prevent “back-feed” from the relay to the ECU or vtec solenoid. 94
[QUOTE=fcm;2040032]Install a 3A fuse on the lead from the ign., [#30] use 2nd ign. free pin on the under dash fuse box.
No fuse is needed on the ECU lead to the relay but a 1A diode should be installed before the relay, [#86], this will prevent “back-feed” from the relay to the ECU or vtec solenoid. 94[/QUOTE]
Thanks again and again…
Totally understand all your sharing…
I will follow step by step with some snapshot,
And post on here…
And hope some one can use it…
