has anyone done this on their da? does the abs light stay on after you do this? how long does it take to do?
There are threads on this. Search.
http://forums.g2ic.com/showthread.php?82563-pics-of-my-non-abs-conversion&highlight=removing+abs
http://forums.g2ic.com/showthread.php?9379-removing-abs-system&highlight=removing%20abs
http://forums.g2ic.com/showthread.php?178280-ABS-Removal&highlight=removing%20abs
http://forums.g2ic.com/showthread.php?197382-need-help-just-finished-abs-delete-but&highlight=abs+delete
http://forums.g2ic.com/showthread.php?206243-Remove-abs&highlight=abs+delete
[QUOTE=spikeymike;2211670]There are threads on this. Search.
http://forums.g2ic.com/showthread.php?206243-Remove-abs&highlight=abs+delete[/QU
i asked if the abs light will stay on and how long it takes not how to do it.
Just by the taking the time to read in one of the threads I have posted:
[QUOTE=thumper;716402]i have a question i have a 93 gsr and i don’t have abs in it
it was removed now the abs light comes on and i was wondering if you guys had this problem as well and how you got rid of it.
thanks[/QUOTE]
Your answer to your question about the light.
By reading on how to do it, you can gauge how long it may take. The amount of time it takes to do will vary depending on the person and the tools they have.
Yeah, we got that the first time.
yes it stays on until you actually unplug the abs ecu thats under the passanger rear seat in 90-91 models, not sure if its the same on 4drs or 92-93 models.
Location of ABS ECU is not dependent on year. It is based upon 2dr. or 4dr.
2dr. is located behind the side panel-passenger rear. NOT under the seat.
4dr. is located in the trunk-passenger side.
strange cuz I just read it on the repair manual, maybe it was the legend section oh well.
i pulled my abs out an had no light come on at all. if it does you can pull the fuse. i have a very easy an clean way of doing this let me know how you did yours or how you want to do it.
Hey bro, what did you do? I’m thinking of using the DB2 PB & MC, with a 40/40 PV, and the lines. Do you have any other suggestions/ideas?
