i bought a 90 teg with an b16 swap…the only problem was the abs light was on…what can be possibly wrong? do i need to change my brake pads, cause i herd that when 2nd gen tegs brake pads are worn out theres a magnet that sets of the abs light…is that true? what do i have to do…thanks everyone…=)
have you checked the fluid in the ABS resevoir? there’s an abs computer with a light that tells you what’s wrong, but the fluid it even easier to check. it’s worth a shot.
thanks for the help man i appreciate it…
Check the fuses there are 3 of them under the hood passenger side labled ALB maybe one of them is messed up…its not making any noises or anything is it?
its not making any noises…ill check those fuses tomorrow…thanks for the input
OH also does the light just come on or does it come on after you hit 10mph?? Might also have something to do with your ebrake, it might be on slightly causing the abs to turn off (light comes on).
yes. the abs light goes on after i drive 10mph. but still i’m going to check my fuses right about now. thanks for the help man.:burnout:
missing a fuse
When i checked the fuse box under the hood i looked and there was only two fuses instead of three so i put another 15a fuse and it works…=).thanks…i have a question if you dont mind…i got a b16a swap and i need to bring my car to the reff. so i can get it smogged and i want to know if a stock 90 teg intake compatable with the b16 motor…thanks for the help yall i really appreciate it!..late ![]()
mine comes on after 10mph, how do i cure this? TIA
Read the above posts…
What is b-series saying? My light somes on after 10 mph too. Is hey saying that a fuse was completely missing and the were 3 sockets for it and he just replaced that fuse?
Yes…check under the hood passenger side fuse box there should be 3 i think 15a fuses labled ALB (anti lock brake)…that is a good place to start if not make sure your e brake is down all the way.
