OK, so I hit a bump in the road and now my ABS is leaking.
I can’t find the source of the leak. Is the master cylinder reservior seperate from the ABS reservior? Can I drive safely with the ABS reservior leaking? Thank you. This really sucks.
That was weird. I cleaned everything up, and refilled the reservior. I drove around, no leak and no ABS light.
Was it possible that the impact from the bump caused my ABS reservior cap to come loose and spill fluid?
I dont think I ever had that problem when I owned your gsr, but it happened all the time with my old ones. The abs system in these tegs is really finicky, when you hit a bump the sensor sometimes trips out and throws the abs light on. I doubt your abs is leaking, probably just residue from the cap. Anyways hows the car?
The car is running good, except for a slight shaking during acceleration. I replaced the axles TWICE with new ones, not re-manufactured. I also replaced the passenger side engine mount and added the front transmission mount but the problem is still there. I’m going to change the driver side engine mount, hopefully that will fix the problem. If not then I have no idea.
Wheel bearings? I dont know, its an old car
watch that abs resevoir, mine leaked for a couple months and ate the shit out of the paint under it on the frame and off of the rear crossmember. :roll:
