Hi people.
My ABS light comes on after about 5 minutes of starting the car. I would think that if there was a problem it would light up once I start the car. Has anyone else had this issue? If so, how did you fix it? What are some basic things to check on before I bring it to a shop to get the code?
Thank you for your help.
Could you pull us the code and tell us what it says? You pull the code the same way as the check engine light ( jumping the connector ) exept you look at the ABS/anti lock light
I hope this is how it is for integras, i know thats how you do it in accords.
To check ABS code, look for the ABS computer behind the rear passenger side panels (on hatch), on sedan it is located in the passenger side trunk. Once you find the ABS computer, you can read the codes from there by way of blinking LED light.
