abs light is on...any way to see why its on?
So i pretty much just stole this clean title 92 gsr last night for 1500$
Og ys1 trans… B18c1 swap :frowning: no b17… But pulls hard… 9/10 interior paint sucks tho… Original color is red…so car runs great with no problems… But the abs light is on…any way to see why its on? And heres some pics
the abs has a computer next to the rear seat on the passengerside behind the plastic under the window it should blink codes then u can look em up. nice find tho.
sweet thanks i have the same problem.your white da has sick rims
just the two pin service connector under the passenger side dash near the ecu and tell us what code it’s flashing. We’ll go from there.
To read the abs light?? Isnt that for the CEL?
when the brake light and abs light comes on i know that means your out of fluid. my lights came on and my brakes shortly went out. no brake fluid at all. refilled and it went away. but i had a big leak. so id say check the fluid in brake and abs
Brakes light isnt on but abs is
sweet pick up
thanks
have you check the fuse? my abs wasn’t working correctly and it kept making an annoying noise every so often. then after a few minutes, the abs would disable itself and the light would turn on. i just pulled the fuse so it would stop making the annoying noise primarily and secondly, i didn’t like the pulsating feel of the abs so now the abs light is always on. i’m going to eventually disconnect the abs computer so the light wouldn’t be on.
ha i just deleted the abs unit its pretty easy to do.
thanks! turns out it was just a fuse
