Where do i check for a code? Anyone run into this problem before? What happened and how did you diagnose it?
90 4-Door 5spd
TIA
90 4-Door 5spd
TIA
teg tips
Try this. Could either be your brake pads are worn past the indicators. Check them first. If not, then make sure they are adjusted correctly and your calipers are not seized or binding.
Lastly, you have a worn ABS sensor.
Just leave it on It looks really cool at night when you have the high beams on, with cruise control on and ABS throwing codes … lol
