How do you reset the ABS computer to after correcting/fixing what the computer is showing?
I tried removing the negative battery terminal.
I couldn’t find any threads on this. wierd.
if its not resetting with disconnecting of the battery have you tried to unplug the ABS computer to see if that works?
[QUOTE=Mr. Burns;2163313]How do you reset the ABS computer to after correcting/fixing what the computer is showing?
I couldn’t find any threads on this. wierd.[/QUOTE]
if its broken, you should just go non-abs. itll be cheaper
