Hey guys I wanna clean up my engien bay a bit I wanna start by deleting that god forsaken ABS unit will I need to change the master cylinder to a none abs one or will it really make that much of a differece? I think I have everything else covered but not to sure I need to do some researching I just figuered I’d start here.
I didn’t change anything, I bought my rs hard lines from a member here that flared and put the new bolt.
Much easier to do if the engine was out. Just saying so you can plan ahead.
ok ok I seen a few things around my main consern is the brake booster idk if I neceseraly need to change it or not thats what I want to find out the most. but how is it working for you? no problems or anything?
Same abs brake booster, 3 years now no issues.
It probably took longer to take everything out .
:search:
alright cool thanks man
So just the valve and the rs line .will everything bolt up or do you need to extend the line and flare it
You will need to extend and flare two lines about 6" long.
