Hey all, I have dont lots of searches but cannot find a solution or anyone that has had this trouble before.
My ABS light is on, yes I realize I could take the bulb out etc… but I would like to fix it rather then just Band-aid the situation.
Anyways I am getting Code 7-4. Which points to a Rear Solenoid or Rear Fail Safe Relay.
So I follow the troubleshooting from the Helm Manual, it has me check the Ohm between the terminals directly on the solenoid.
It is 3 ohm. (which is normal) accoring to the Helm
I check the front ones also and they are the same result.
The fluid level is normal.
I have a second ABS computer, so I switched them and it still shows code 7-4 which somehow tells me the ABS-ECU is working.
So I unplug the harness and check the wire End to End for Continuaty and everything looks fine, I get continuaty properly from the Rear Fail Safe to the ECU.
THe next step is to check the blueish wire from the fail safe to the Solenoid, this also checks out fine. Continuaty is okay.
The only thing I have not tried is to swap the Modulator (which I have a spare from a wreck, that I saw was working).
I have about 5 fail safe relays, so I hook up some wires direclty to the relay and you hear a big click, as the book mentions, there is no continuaty until I hook up power. this indicating that the relay is working fine. I have even tried to switch a few, and nothing.
I am at a total loss.
Ohh I guess another thing I have not tried is to bleed the ABS system.
Does anyone have any thoughts that I can try on this repair? Maybe running a wire from the Harness in the back to the Rear Fail safe? just for a test?
ANy help is appreciated.
(BTW- The car is a Canadian Black 93 GS-R)
