ABS wiring.
im deleting my ABS and i want to get rid of the extra wiring. There is a large pink connector on the passenger side by the door… does anyone know if i can delete everything in that connector without hurting anything else? its a pink connector so im assuming that its fine because pink connectors are used to symbolize the abs wiring.
Be carefull with the harness under the hood. When I removed my ABS, I cut the harness that went to the ABS module and Underhood Fuses for ABS. Turns out, there is ONE wire in that harness for the Hazard lights. Had to hunt it down, splice it, and reconnect that one wire so the Hazard lights would work again.
What color wire was that? I had a wire earlier that seemed off place and I wasn’t sure to cut it or not.
I have strange issue with my abs:
if I leave the main fuse in it f*ckin chirps?! lmao like a squeaking belt…but… it isn’t a belt. so I pulled the fuse…i don’t have abs now (so what?!) but it’s interesting…anyone heard of this?
/threadjack over
Probably a white/green, for some reason on USDM G2s w/ABS the fuse for the hazard lights is in the ABS fuse box, [AUX fuse box], on CDM G2s it is fuse 34 - 10A, [hot at all times] in the engine bay fuse box.
If it is that lead you can just run it, with an in-line fuse, to the constant power free pin on the under dash fuse box so you can get rid of all the AUX fuse box and it’s wiring. 94
I’m sorry but can you clarify what you mean by AUX fuse box?
