ac bracket,compressor doesnt line up
ok so i have a 90 with an ls/v.i have a b18b1 bottom end.im in the process of putting ac on my car.i went to the junk yard and found the bracket and pulley that i need to mount the compressor.i was doing some test fitting and the compressor when mounted on the bracket the belt wont line up with the pulley.the ac stuff i have its from an 91 ls.idk if it matters.can someone give me some advise or maybe a sugestion.thanks
my a1 compressor fits my b20b but my ac clutch started squeeking after a while (2 months) so took the belt off
so whats your point??not trying to be rude or anything.
if its a b series it should fit
oh ok.thanks.the bracket and the compressor fit.but they dont line uo all together with the crank pulley.
o have you tried puting your crank pulley from your old motor on to your new motor?
i dont have an old motor.the car came with it…
wher did you get that ac compressor from?
from a 91 ls.this guy was parting it out and sold me everything ac related for 100 bucks
damm that thing is really off you should off gone to the junk yard
to look for the compressor?i got the bracket from the junk yard
yeah for the compresor if it doesnt work dont they give you money back?
i have mine still if you want you can try mine on if it fits just make me an offer mine just need to have ac clutch replace
but arent they alll pretty much the same size?
damm i just checked the ac clutch it self cost 99 bucks
idk cus if your i from an a1 it should fit you b1
daum!!thats alot…might as well get a remanufactured compressor…it fits but just doesnt line up.
so the one u have is a reman? maybe they used the wrong clutch
no…its from an original a1…but im saying if i buy yours i have to replace the clutch and thats 99 bucks…i might as well but a remn one.lol…but do you have any idea why it wont align?
wish i did i always tought a b series ac s and ps were all the same
i thought so too…hey but thanks a lot for your time trying to help me out.much appreciated…hopefully some one else can give me some input on this.
