My ac compressor is not working and im planning to replace it soon. Is there any easier way to take it out. How do you get to those 2 bolts on the lower part of the compressor that bolted to the bracket? Thanks in advance.
use simple ratchet get your hand down from the top. i had to use both hands, one to hold the wrench on and the other to swing the handle. stick your left hand under the front bumper theres a small space that just has enough room to put your hand through.
its cake bro like 2 or 3 bolts dont forget about the power steering too
an even easier way to pull the compressor out is to remove the ac condenser fan. its two bolts right on top of the core support, then unplug the fan and then you have easy access to all 4 bolts and you can pull it out easily.
like Cream1316 said don’t forget to unbolt the power steering pump and move it out of the way it makes it so much easier to take out the compressor.
