AC delete duct question
what exactly is this duct deleting? can someone reconfirm this, but iirc, it is deleting the evaporator assembly (basically the box that looks similar to the air filter box) underneath the dash correct?? Also can i get another confirmation that the duct is #9 in the diagram below??? thanks!
#9 in the diagram below:
[QUOTE=AV turn’d DA;2168034]what exactly is this duct deleting? can someone reconfirm this, but iirc, it is deleting the evaporator assembly (basically the box that looks similar to the air filter box) underneath the dash correct?? Also can i get another confirmation that the duct is #9 in the diagram below??? thanks!
yes,yes and yes.
Thanks for the input, now I just need to get one now lol
Good luck with that… They’re not the easiest thing to get a hold of.
You also need the rubber grommet for the firewall. The one on AC cars has two holes in it for the AC lines… on the non-ac cars it is just a blank rubber plug.
[QUOTE=unified112;2168055]Good luck with that… They’re not the easiest thing to get a hold of.
You also need the rubber grommet for the firewall. The one on AC cars has two holes in it for the AC lines… on the non-ac cars it is just a blank rubber plug.[/QUOTE]
I’ve already got that plug, paid $7 bucks shipped for it, yaaaay!
Sounds like you’re good to go then.
the duct are disc from the dealer so you can only get them used if you want one i have one for sale used fo 50 shipped let em know greazemunkey73@yahoo.com
