ac fan
Really simple questions here is the ac fan held in by 2 10 mm bolts? Where is the connector located that the fan plugs into?
Can anyone snap a quick pic of the AC fan connector’s location please?
If I remember correctly I believe that it is just two, and the bottom of the fan slides into a spot on the bottom of the stock radiator. The AC fan has that green connector but I remember it being DEEP in there and hard to get to. What are you trying to do?
The previous owner removed the AC fan so I’m trying to install a new one but I can’t seem to remember where the connector is and I can’t find it so I’m wondering if it got cut
Ok so standing in front of the bay it shud be on the right side of the ac fan near all the steel lines that go to the reciever/dryer…its green connector.,maybe they hacked it off if u cant find it bcz its easily visible
Is it near the AC Compressor?
do you still have the a/c unit? it should be with the 2 relays mounted and wrapped in rubber covers to the bottom driver side. closely check those wires since it could have gotten cut.
