ac/heater blower not working, started car turned on the blower to the lowest speed work then it just stopped. turned ignition off and back on still no response.
your blower motor probably went out.
ok so turn your car on turn it to the highest setting which i believe is 4 this will determine if your blower motor fuse is blown or your blower motor is done for…or you need a new blower motor resistor block–this is what lets the current flow on each speed 1 2 3 speeds are connects in series and they have diodes wich limit the current…speed 4 is on its own circuit so it can never blow… if 4 works and 1 or 2 or 3 dont then u need a blower motor resistor block if no speedds work then u need to check the fuse if thats good then u need a new blower motor…
problem fixed thanks
was it the blower motor or resistor block? i’m having the same issue (no air blowing at all) and just researching.
it was the blower motor
