Alright, i was a good boy and did a search, found out that i need to replace the resistor coil because my AC only works on the last 2 settings. However, i went to the Acura Dealer and they didn’t know of anything called the resistor coil. Is there any other name that it might go by? Resistor fan maybe? Anything else it might go by? I would really appreciate your help. Thanks a lot.
when you say that your ac works only on the last two settings, you mean the fan only comes on the third and fourth speed right? if thats the case, the proper name for the part your looking for is the blower motor resistor.
Thank you very much ![]()
