I’m looking trying to find the part numbers for the tensioners as needed, if i’m thinking right the alternator swivels for it’s tension, but the power steering and air condition compressor has their own tensioners. Anyone know the P/N or can help me by pointing these out in the diagram. i’m trying to gather all these parts to have them here by friday. Thanks SO much in advance. Also the P/N to the rear main oil seal too please.
Another question not relating to tensioners, but i dont want to post up another thread. Clutch wise, i have a 90 RS DB1 when getting the clutch i base it off the trans, correct?
The alternator swivels and tensions itself.
The power steering bracket has a bolt-tensioner where you tighten the bolt to raise/lower (tighten/loosen) the pump.
The AC is the only one with an accessory-pulley tension system.
You want a clutch for the '90-91 Integra… '92+ are different.
As far as part numbers, go to http://www.acuraoemparts.com/delray/jsp/catdisplay.jsp and do some homework… They’re all listed in their respective categories.
Regarding the first link… #15 is the swivel part… but you need the pulley, the tensioner bolt & nut etc…
#15, 16, 17, 18, 20, 21, 22, 23 would make up the entire tensioner setup. Providing you have the main AC bracket (#14, 24, 25) to begin with.
Regarding the second link… Part #12 and 14 are the brackets that mount to the block.
Part #18 secures the pump to said brackets.
Part #13 will tension the belt by pulling the pump UP towards the top of the adjustable brackets (#12, 14).
Part #30/31/32 are the bolts to secure the brackets to the block.
thanks man alot, i appreciate it. i have everything pretty much for the a/c compressor, my tensioner bolt was broke i believe…i’ll order that. thanks man
