Accord lip
Im new here and i have a 90 Db1… Alright i know that an accord lip can fit with modification but how hard is it truely does anyone have a write up i searched for two days through the archives and through the exterior forum but couldnt find a solid how to or write up
It should be really straight forward when you have the lip in front of your bumper. Just have a friend hold one end and you the other and line/bend it to your bumper and see what’s needed to be cut.
Then in order for it to contour to the bumper’s curves, use a heat gun and then some tapping screws to hold it in place. You can always use doublesided tape to hold it in place then shoot it when the screws… your choice… hope this helps.
X2…had to do the same thing when i modified a DA lip for my crx.
make up some end caps for where you cut it to, looks weird without.
rear lip looks good on your car man… i was refering to the front lip though for right now i may have to try it out soon
Try this thread http://g2ic.com/forums/showthread.php?t=176264
http://g2ic.com/forums/showthread.php?t=180122
