Acura CL leather seat swap ?
I gave it a shot and tried searching, as well as tried the teg tips, as well as checked honda-tech.com and tried team-integra.net to no avail - eveyone tells me to come here. :wave:
Well when I bought my DA it had Ractive :roll: “racing” seats in it, that suck, even though they’re Ractive and suck by name alone - I’m getting pretty sick of feeling like I’m sitting on a skateboard as I drive…
So in my searches locally for some seats - stock preferred - I came across a few DA’s with grey / blue seats and passed on them due to colour - but ended up stumbling on a 1997 Acura CL with leathers, the seats are in GREAT condition - and the yard wants $300 for them… Which IMO is well worth it for comfortable leather seats…
I measured the CL’s at 20" from the widest part across, 19" from front to back, and from base to mid-extended head rest they appear to be 38 or 39" - from floor to roof the CL is 40" (to the frame) with another 6 or so inches from the headrest to the very top…
I measured the DA at 19.5-20" across, 20" front to back, and they sit at 36-37" high (anyone want to confirm? I was a little shakey and awkwardly positioned to get a really solid measurement…I may be off) With the roof being 38 to the frame as well (measured by someone else near me as I played with the CL, was blurted out and I didn’t double check) with an easy 6+ inches from the head rest to the roof in the DA as well…
My Ractive seats sit so far side to side they lightly rub the door when they’re reclining, theres maybe a half inch to an inch between the sides and the center console, and they sit high enough that when my hair is spiked - it hits the roof. I’m 6’1 if it helps… And my hair was only 3" long when I had it done up that way… Also if it helps.
So my -after novel- explanation question is… Measurements aside (they sound like they work fine) would I just need to drill some holes in my brackets, or should I grab the CL brackets too, or what would you guys advise to make these things fit? Going from rice to sexy leather I think would be a nice upgrade…
(1997)
(2001)
They look pretty close to the '01, but are '97 obv. I can grab the rear’s which are also mint but I didn’t check the price, not like they’d fit anyways…
Actually… That might be worth a check… Even if I had the rears sitting in storage in case I wanted to sell the set :slight_smile:
Any help or input would be appreciated, or any experience with CL and Integra’s swapped over - if they fit in a G3 they’d fit in a G2 - with some rail work at least.
Thanks in advance !
