Acura Preventive Maintenence
http://www.ahm-ownerlink.com/Maintenance/maint_prev_maint.asp
[B]
PREVENTIVE MAINTENANCE FOR YOUR ACURA
Here are some simple steps you can follow to keep your Acura running well all year long.
Acura Maintenance Checks
Changing Your Oil and Oil Filter
Keep your Acura running like new. Between scheduled maintenance services, periodically check the following items:
Engine oil (orange loop dipstick)
Weekly or when you stop for gas. Add oil if the level is below the lower mark.
Engine coolant
Weekly or when you stop for gas. Check the reserve tank; don’t remove the radiator cap - the fluid is hot and may gush out.
Windshield washer fluid (blue cap)
Monthly. Frequent users should check each time they get gas.
Automatic transmission fluid (yellow loop dipstick)
Monthly
Brake fluid (large gray cap)
Monthly. Low brake fluid could indicate a problem. Take your Acura to a dealer for service immediately.
Clutch fluid (small gray cap, manual transmission only)
Monthly
Power steering fluid (red cap)
Monthly
Tires
Monthly. Check pressure. Check tread for uneven or excessive wear and foreign objects.
Battery
Monthly. Check condition (level of fluid or color of the indicator). Check terminals for corrosion.
Air conditioning
Weekly. Turn it on for a short time.
Lights
Monthly. Check them all – head, tail, parking, and brake lights, high-mount brake light, turn signals, back up and license plate lights.
BACK TO TOP
Oil, Oil Filters, and Your Vehicle
Your Acura relies on clean, well-circulating motor oil to keep its engine running smoothly. Unclean oil can accelerate engine wear and cause abrasion, resulting in expensive repair bills. To ensure the integrity and performance of your vehicle, change your oil and filter regularly, according to your Maintenance Schedule.
Oil Filter
The replaceable oil filter traps contaminants and keeps them from circulating throughout the engine. Acura recommends using Acura Genuine Oil Filters.
Choosing a Motor Oil
Lighter oils flow easier once the cold engine starts, bringing vital lubrication to moving parts. Please consult your owner’s manual for the recommended motor oil for your model.
Engine Oil Additives
Today’s engine oils are formulated to maximize performance. Additives are unnecessary and increase the cost of operation.
[/B]
