adjustable cam gears, valve clearance
i was wondering if it was the same procedure to adjust the valve clearance with after market cam gears and different timing?
Valve clearances stay the same.
so you just put it at tdc and adjust the clearance same as stock?
No not stock. Same as the cam manufacturer recommends, which could be same as stock but might be a few thou difference. I meant that the process with adjustable gears etc. is still the same. The clearances don’t change from the original set by the manufacturer.
oh ok i understand thanks a lot.
