Adjustable Radius Arms
the first sentence of the first post makes it pretty obvious in that adjustable radius arms allows you to adjust the degree of caster.
oh caster…nevermind
I found a pair, I’m Putting them in tomarrow. Tell ya how it goes.
Wow what a difference! Car doesn’t wander all over the road and steering feels super tight. Making the holes bigger for the bolts was very simple all you need is a pnematic die grinder (A dremel will work but it will take longer) and a carbide bit, takes maybe 2 mins per rod, don’t bother with a drill or a drill press it takes way too long. Also performed the rear camber correction with the shims brought it right to within factory specs. Defintly recommend both mods.
