anyone know anything about these? i just ordered some, he said they are adjustable to adjust camber, but i guess its built into the upper ball joint…
are you sure they were made for our cars? cuz the only adjstuable ball joints i know of are for 96-00 civics. our upper control arm and ball joint are one piece. so in order for you to use them, you would have to some how chisel out the old ball joints. but if you want to use an adjustable ball joint type of camber kit, use the one from Skunk2.
well, he said adjustable upper control arm ball joint, so im guesing its just the ball joint…and if thats true, i guess i would be getting the whole upper control arm, if not, then it might just be a camber kit…if it is, im gonna be ****ing pissed…
bump
thats what i have in my car… it will be better coz u dont have to push the whole control arm outward. the stock ball joint is removable… clean it first so you will know how it is stucked in there… and the secret weapon… VVL-800… lube that biatch and hammer it out, make sure when u put the new one that it is aligned properly. you’ll see what i mean, theres a line in the center…
re: control arm
What degrees does that kit adjust? I want a kit that can adjust from like -.5 to +3, but doesn’t seem to exist. There isn’t anything that can fix my negative stock camber now, and my future plan to slam my teg. Sucks!
