when I turn the screwdriver clockwise on the adjustment gears for the horizontal adjustment, does it make the light go left or right? Also on vertical ajustment, when i turn clockwise does it go up or down? Im asking because Im not noticing any changes when I turn the adjusting gears.
It should be outlined pretty well inside of this archived Teg Tip:
http://forums.g2ic.com/tegtips/lighting/9.html
As for the adjustments left or right, I would assume it’s counterclockwise; Right, right, left, left. It’s best to do this at night so you can see the lights changing position. Hope this helps you out man.
ok figured it out. Previous owner used wrong bulb and it was just dangling in the housing lol. Gotta go out and get the proper bulb for it.
