Advice from people with body work experience. ...
So my car has the old Honda cancer. It’s not terrible, non the less it’s still an issue. I have 0 body work experience. How should I go about this? Should I try to tackle this by myself? I was told to use bondo glass. I guess it’s that or take it to a shop. Any advice on what to do would be great.
take it to a shop cut and weld.
Coming from someone who does it for a living… If you can’t cut and weld, it’s probably best left to someone who has done things like this before.
If it’s just surface rust, it can be taken off with a grinder… then seal the bare metal with direct-to-metal primer. Then paint, then clear.
If all you were going to do is ‘patch’ the rust and not paint it… just leave it alone. Doing it half-assed will surely make things worse.
