i am looking into doing aftermarket control arms. Does anyone have these?? do you have pics. i really need help on this one of my ar broken and i need to replace it. i am looking to spend around 400. Also I want to replace my bushings too what are the best of these too. and where to get these goodies.
I have the Energy Suspension bushing system forthe entire car. It is great! The difference isamaizing. Definitly recommended. Bought through Summit for $140 with motor mount inserts. If you get the inserts be aware of the new response to acceleration.
With a lot of help from a neighbor. I did the work of removing the parts from the car. The easy part. Then as I said with a lot of help from my neighbor we cut, drilled burned and the old out. It did take some time but with the car on jacks that it appeared to be what I had. The nice part with the new poly bushings,the are mainly a three piece set up. So getting the new in was not as hard as we thought. The upper arms did give a little trouble, but not much. Justmake sure to grease the heck out ofthe new parts and you shuoldn’t get squeaks. Ihave had them infor just under a year and no problems at all. The motor mountswhere done by my mechanic while he hadthe engine lifted to get the new timing and acc. belts replaced I had him do the inserts at that time. Good Luck!!
