aftermarket axle help
Im running in to a problem with my car being as low as it is. I keep chewing up differentials like there is no tomorrow. I was told that being as low as i am that every time i hit a jarring pothole or bump that its is forcing the axle in to the tranns, and beating up the diff on stock axles. By running an aftermarket set of axles ie. gators, hasports, driveshaft shop(i was also told they can make custom axle lengths) i should be able to minimize diff destruction. Dose anybody know any thing about those axle manufactures and if they can make a custom length axle??
ive not heard of anyone making custom integra cv shafts. i know someone does…but dang you will be spending money! it would be cheaper to just raise your car up a tad to be honest. you will still look good, just helps with suspension tuning and geometry angles.
