aftermarket braided fuel fine and filter.
ok so I want to remove my fuel lines for a new setup.
I want to run a an fitting from the firewall-braided line-aeromotive fuel filter-braided line-fuel rail.
I need to find out what an fitting I can use from the firewall.
has anyone done this?
If you have instagram, search for a page called fueltukd. They have kits for any Honda application for around $100 shipped.
As far as DIY, the last I checked, it was a -4 AN setup. Hope this helps.
Coulda sworn it was -6 for the fuel line… one way to verify, go to chasebays or somebody that sells a kit… then look in the description of what’s included. It will say the size u need.
EDIT: yep, -6…
yeah I think it is 6. now I just have look for the right fitting to to make my fuel line and the fuel filter.
for those of us who dont use instagram is there a diy kit to buy?
[QUOTE=dlo253;2293207]Coulda sworn it was -6 for the fuel line… one way to verify, go to chasebays or somebody that sells a kit… then look in the description of what’s included. It will say the size u need.
EDIT: yep, -6…[/QUOTE]
chasebays is $200
its going to run way cheaper to make it our self.
I’ll post pics if I make mine soon.
making braided lines isn’t even hard, and its easier when you use the black composite fiber braided lines instead of the stainless.
Do you guys not have Evco stores? Most any fuel or oil line and fittings are easily found there.
not in south cali, we have to go to pep boys or local speed shops wich I hate cuz the people there are old veteran racers and think less of anything that aint a v8.
