Aftermarket Clutch Spindown Time
hey, i got a stage 3 XTD (ebay) clutch… it grips really hard but when im sitting in my car in neutral and push on the pedal it takes quite awhile for my clutch to spin down… this contributes to the grinding of second and third when im in high rpm’s… anyone know how to fix it?
No idea!! i have the SAME problem! would love to know the answer… bump!
did it do this when you first got the clutch or did it just recently start happening? i also have the stage 3 xtd and mine started to do that after a couple weeks but i ran my car hard. Since the clutch engagement is so hard, it actually starts to tear your transmission apart. My syncros went to shit fast but its only in higher rpms i get a grind. normal driving is fine, so if it just started happening recently and not straight from the start its probably ur syncros starting to go out too. just my .02
maybe a lighter flywheel will help?
i had a stage 4 XTD 6puck and never had that happen, but i also had an 8lb flywheel, so i cant really help much except to say mine never did it
it was doing it since i put the clutch in… i had a new clutch cable and i assume it broke in and steched out alittle bit, the clutch catches alllll the way up… its a pain in the ass to drive like that… is there a clutch cable adjustment at the pedal??i need this fixed ASAP
cmon chad hit me up i got the book and we will try to check it out or u could just buy back ur flywheel from ur bro and try that sir!
bump…
bump… I NEED HELP PEOPLE…lol
Just adjust your clutch cable free play at the clutch lever by the tranny, turn the black adjustment nut. Just turn it in whichever direction changes your engagement further towards the floor.
yea that actually helped out mucho… thanks homie :bowthank:
