hey i bought a new steering wheel and hub kit for my 92 teg i have the stock wheel off buy need help with getting the new wheel on dosent seem like its fitting correctly think maybe im missing a step somewhere thanks
What are you having problems with? You should be able to slide the hub over the steering column and secure it with the OEM nut you removed to take off the stock steering wheel. Then use the machine screws to mount the wheel to the hub.
well it sticks out way further then the stock wheel didnt think it was suppose too also the little ring with the 2 tabs on either side whats that for ?it came with the kit and also the horn how do you hook up the horn ?
How the wheel fits in regard to placement close or far from you is going to depend on what parts you buy. Some steering wheels are flat, others are dished and push the wheel towards you, also, some hubs are different lengths. The ring w/ two tabs is for the horn button, those tabs should have wiring connectors (female spade terminals) attached to them which go to the horn wiring.
