There is some resistance in the pedal when I push it with the adjuster screwed all the way down… but you can only feel the resistance in the pedal when it gets half way down.
And I can lift the lever up and it goes back down by itself but its suppose to have much more resistance right?
Are you talking about the lever connected to the tranny? I don’t think you are supposed to be able to pull it up by hand. I know when I changed my clutch, I put the release fork spring on wrong. Unfortunately, I didn’t realize that until I got everything back together and had to take everything apart again. HTH.
It sounds like to me that you have to much play on the top end of you clutch pedal… ( you should have some but not as much as you say there is) you might need to pull the cable toward you and tighten that plastic screw all the way down, and losen it untill you have little play on the pedal… read the book on that part. ( the screw is right about the lever you cant miss it)… but i could be wrong … if i was ther ei could fix it or if i had some pictures…:read:
That it was I thought. But the spring will fit on several different ways. Hope you got a haynes manual. I had to stare at the diagram for a while before I figured out how the spring was supposed to fit on.
