Aiming JDM headlights (ATTN LEIF)
Re: i’m having trouble aiming my one piecers
Originally posted by 92 RS
[B]So, to aim them, do you just stick a flathead screwdriver in the little teeth deals and keep on turning it a few degrees at a time?
i just tried that and must have spun that round part with the teeth on it 10-15 times. was parked about 20 feet away from the garage door(white) at night time, and i couldn’t see my lights moving at all. about half way through i had a friend put his finger in a spot where the light was hitting, and turned about 7 more rotations. i didn’t see the light move AT ALL! I did it for both sides. Is it a REALLY fine adjustment knob, or could both mine be broken, (or maybe they’re adjusted all the way?)? Any input guys? My lights are aiming really low. Thanks
Brian [/B]
Sorry, I didn’t see this post earlier. To answer your question, you have to turn the screw a lot to get anything. And no, DO NOT use a flathead. You have to use a Phillips! Unfortunately, the phillips screwdriver rounds off the teeth, that one I have no clue how to solve. But once aligned, you don’t really have to touch the lights again (at least for quite some time). Hit me up with an e-mail if you’re still having problems.
E-DA9 -> Thanks bud! I’m assuming you got your 1pcs all hooked up and everything ok?
Regards,
Oz
ARCHIVETHIS
