as the title says,
i tried using the cog wheel but it doesnt lower the beam it actually just pushes the headlight housing forward… i want to know how to lower the beam and keep the headlight in the same position
as the title says,
theres 41 views… im guessing no one knows how to aim them?
oh you know…something like that happened to me.
what i found out was that the black metal base that is mounted on the car, was actually stopping the movement up/down. so try looking around your base make sure nothing is touching or its not interfering, cause i was trying to aim them up, but it wouldnt, so i used a flat head screwdriver to pry the base to not touch the headlights themself
hopefully thats what you’re expericening
yea ill try that…
