Not sure if there is a thread for this topic already, but I just got my 2nd teg 91 LS and I was wondering if anyone has encountered this problem. My A/C won’t even blow air. The led lights work but as for blowing any air it doesn’t work. My model doesn’t have A/C but I need this fixed as quickly as possible for use of the defroster… If you guys could help me diagnose the problem or give me any ideas on what to check that would be great. Could it be a fuse??
ps. I have a haynes manual
better yet what fuse controls the actual “blowing” of the air out of the vents? if anyone knows or has info on this it is greatly appreciated. thanks
Not that anyone cares but for posts sake. I found out that my blower was unplugged after actually “goin in” and taking a look. I plugged it back in and another plug that was unplugged which was causing my seatbelts not to work. Now they work but the seatbelt alert stays on with this constant annoying beep* Beep* beep**… Oh yeah and my a/c only works on levels 3 and 4…
search blower in the serch box an it will tell you how to get all 4 speeds back i had the same problem an just fixed it a week ago i fill try an find the thread an post it for you
thanks!
The blower resistor is most likely the problem, depending on what speeds work.
What speeds do work?
Check the seat belt connector under the seat, the warning chime is controled by the ICU, mounted to the back of under dash fuse box.
Do the intermittent wipers work or the rear window defog? 94
Yea it was the seat belt connector underneath thanks fcm…
and the only speeds that work are 3 and 4
replace the blower resistor that should fix it that what it was on mine
