AL: b17 ys1 full gear set
I recently picked up this gearset and now I want to sell it because i already habe two of them. Its no doubt a b17 gearset. I counted all of the teeth and they matched exactly to a b17. I was told it had a 2nd gear grind and I definitely know why. The synchro is sitting flat on the gear and the dog teeth are worn. They still shift through the gears fine though. The 1st,3rd,4th, and 5th gear synchros all appear to be in decent shape and within spec. Let me know if you have any questions or concerns. $200 plus shipping
bump for a deal. good luck with sale
Thanks for the bump! Got the shift forks for it too. I forgot to mention that . These can swap in any ys1 casing. Also if anybody wants to pay for the parts for a rebuild, ill throw them in these gear sets for free.
damn, only if your 2nd gears weren’t worn. this is a total perfect grab for a hybrid transmission. I have two YS1 transmissions both fully working, and I am debating on doing a custom build transmission. gsr short 1,2,3 then ys1 long 4,5. I already have an Mpower LSD. hmm good luck with your sale, I wish I found you sooner.
The b17 tranny I have in the car now has a worn 2nd gear just like this one. I replaced the synchro and spring and its fine . No problems at all shifting or grinding. I’ve thought about making a “gsr hydro” / b17 tranny too. When you use an ls 1st and 2nd with a 4.4 final drive, it gives you the same exact gearing of a gsr hydro without the benefit of a dual cone synchro on 2nd Then use the b17 3rd-5th.
Do you still have it? How much shipped to 89148
still available? if so im interested in buying it.
I think ive decided not to sell it. Im probably going to build another car and use this gearset in a hydro casing. If I change my mind again, ill pm you
