Alarm Problems
Alarm worked fine, locked, sounded the alarm siren, and opening anything with it on, would set it off.
Now, I did some wiring with the headlights to fix some of the problems from bad wiring from a previous owner. So now, it locks and unlocks the car just fine. Lights flash when I do it. But the Alarm siren doesn’t beep when I do it, and I can “lock” the car even if the door is open, nor will it go off if it is all locked up tight, and I open the door.
Could I have blown an internal fuse in the Alarm box while working on the headlights? Like shorted something out?
Any help would be great, thanks.
I would search online for the alarm installation wiring diagram, make sure everything is wired up properly, or that you didn’t knock a wire loose when you were messing with it.
No wires came loose, I never even came close to messing with it.
[QUOTE=Boosted_90Teg;2157114]No wires came loose, I never even came close to messing with it.[/QUOTE]Your alarm is in valet mode, [door locks and light flash work but no arm/disarm chirp or alarm functions], take the alarm out of valet. 94
