Hey guys well I lowered my car finally, no pics yet, but now I got a problem!! :mad:
My tires are going bald from camber wear as some people say. I say this because some people say toe eats tires and some people say camber eats tires was up? Anybody truly knows??
Well I got it and alignment today and here are the results, i payed 25 and they just fixed the toe though need to get a mber kit to be able to fix the camber.
caster was 1.6L 1.7R they said it was good
Camber is still -1.6L -2.6R (Looks the same to the eye on both eyes) :hmm:
and toe was -0.75L -0.10R and I fixed it 0L 0R…
So im going to be watching at my tires every week see how it goes. I used my car after I lowered for three weeks about 1500 miles total and started seeing a little wear on the inside already so im going to drive it another 2 weeks with that fixed and see how it goes.
That really depends on a lot of things. Mostly, what type of driving your planning on doing and what the rest of your suspension is set up like(spring rates, sway bars, etc…)
-nino
low air pressure will definatly wear off the shoulders on the tires. combine a lil -camber/toe and splash of low psi and BAMM (emril) you have the perfect recipe for worn shoulders. and just the opposite too high of a psi will wear off the center of the tires. but it really comes down to you’re individual setup and driving habits. after all it is you’re car and you do the driving, so how you’re tires wear is a result of how much effort you take in maintaining them.
Hey speeddaddy thanks for the info remember me I bought your konigs blues, the ones I have installed on my car. Ride is kinda good but I had the two front shocks blown without me knowing.
