wats up everybody. I got an alignment today and i forgot to get the proper specs for my suspension setup. the alignment machine at the shop i go to only has Factory specs for front and rear camber. im currently sitting on tein s-techs (greens) with kyb gr-2s. i have front ingalls camber kit and password jdm rear camber kit. The alignment machine at the shop can be adjusted for aftermarket suspension, only thing is i need specs. if anyone has a similar setup with specs that info would be very helpful. Thanx
The specs I found are:
Toe - Front 0 Plus/Minus 2
Rear in 2 plus 1 minus 2
Camber - Front 0 degrees plus/minus 1
Rear 0 degrees plus/minus 1
Hope this helps
thanks homie thats what i was looking for. greatly appreciated!!!
FYI those alignment settings ARE factory specs, at least according to my service manual. Although rear camber is actually -0 degrees 40 minutes plus or minus 1 degree, but essentially that is what is posted above.
Unless you have some sort of special requirements for alignment, i.e. for autoX etc. then just having aftermarket suspension doesn’t mean you NEED different alignment settings, but it gives you the option of dialing in custom settings if desired.
Mine settings are:
Toe front: 0*
Toe rear : 0*
Camber front : -3*
Camber rear : -3.5*
[QUOTE=japanjay;2212977]Mine settings are:
Toe front: 0*
Toe rear : 0*
Camber front : -3*
Camber rear : -3.5*[/QUOTE]
That’s a LOT of negative camber, I see worn out tires in your future unless it’s a race car. And even then if it was a race car you’d expect to need more negative camber up front than in the rear seeing as there’s more weight up front and generally more tire rollover.
