all honda stroker kit
i might b stupid but here it goes i recently put a b20b in my teggy well long stoory short it spun a bearing after a month no boost no nitrous no rapage of any sourt. ok on with my story i work for advance auto parts and i was just bull shitting around bc i dont feel like buying another moter and kinda iffy takeing the crank to b machined so i found a company that produces our cranksand found out that the b18a-b cranks and virtuly the same as b20 the exception is the nose idk what the diffrence is but the same stroke same rod and main sizes after i found that jus looking n the book some mor i found that the f23 moters same every thing but stroke the b18-b20 stroke is 3.5 and the f23 is 3.87 what im wornding is will it work and if your good and numbers and such what would the displacement be thanks and if u have hered of it bing done let me know what it was like
:bump:
im sorry, there are three periods in that post and two of them are decimals.
aside from that, i dont understand where the F-series motor comes into play, so ill say this:
F-series parts are F-series parts and cannot be used in any other family besides the F-series. same goes for B, D, H and K motors too.
onto your B20/B18 crank inquiry; the part numbers are the same because the B20 has a larger bore (diameter of the cylinder) which does not effect stroke at all, and stroke is only effected by the crank and, much less likely, the connecting rods. if you put a crank from a B20 in your B18 it will still be 1.8L. if you put a B18 crank in a B20 itll still be 2.0L
also, try getting a better grasp of typing, aside from helping you to look a bit more educated, it helps us to be able to understand you and answer your questions more accurately. i have no idea what you meant by:
…what im wornding is will it work and if your good and numbers and such…
and im sure with a little more effort put into your topics there would be more responses.
what i was asking if the f23 crank is longer because the rod and main jurnals are the same as the b18-b20
[QUOTE=OMG Its Weasel;2106291]im sorry, there are three periods in that post and two of them are decimals.
and im sure with a little more effort put into your topics there would be more responses.[/QUOTE]
not true
people use b series trannys with h series motors and same with k series and the s2k f20/22c
people also drop the s2k f series cranks into kseries as an oem stroker kit so this guys question is a definate possibility.
if all the measurements are the same go to the junk yard and grab the crank in question and see if she fits.
be an innovator and blaze your own trail bro.
i say go for it
thanx for the positive words g2 as for the rest thanx for the input but we will try i keep u posted
yup i seen the stuff mentioned above…K series pistons drop right in a F23 motor…and the H22 head bolts right up on a F23 block to create the imfamous Frankenstein G23…so it is possible…many things are
IF the F crank bolts to the B block make sure you can get appropriate bearings. also make sure you can find appropriate length rods so the pistons dont interfer with the head. and along with that have to check with the rods to be sure not to have to adjust wrist pin height on the piston to avoid the same.
thanks for the suport and the bering sizes are the same rods are 1.771 or so and the mains are 2.165
very interested -subscribed-
This sounds like a legit idea. Mabye source a crank from a junk car and check clearances and such. The only part that would steer me away is the R/S ratio. Have you done the math yet? With that much more stroke I would suspect sidewall load will increase greatly making it a terrible engine for boost, or any type of forced induction. It will also not be good for what all Honda engines are good for anyways, revs. If it were me, I’d stick with another B20 crank. Someone correct me if I’m wrong. Still a cool idea though.
i dont want to go boost or any thing any i have my buddies at monster moter sports doing the math and going to get back to me in the next few days
The F crank will work on H series motors. K 24 crank will work on an H22A4
If you want a 95mm stroke B series crank, use the B20A crank. You can properly set it in place with some machine work and it’ll give you a crap load more TQ. 86x95 will be a great engine to play with.
Just remember, any and every stroker motor that you build, knife edge the crank and get some light weight rods/pistons. This will ensure a longer life for the engine.
