:pupeyes:
1991 Integra ls all stock
Ok I am new to THIS forum but I am on others a lot(1996 Impala ss) .But I have searched and read up on the details that are already on here>>>>And here is my problem ,
The alternator went out on the car and the Battery light never came on , so I replaced the alternator, cleaned all the grounds made sure all the wires were tight,and the battery light is now on >I had it load and charge tested twice and that all checks out and I have reset the computer by pulling fuse and of course it was disconnected when I replaced the alternator.
car is driving and charging fine other than the light, seems normal other wise
What should be my next step?? replace/re solder ecu?? My fuel pump went out 10 days later But it had 221000 miles on it it was the original one, so that may or may not be connected so i have to ask will it hurt it to drive it??? thanks all in advance Bob441
Also why does my post appear as a long skinny line of the instead of the way i spaced it all out???
